PPI advice
Posted: Tue Aug 05, 2014 12:53 am
by SWMS
So, when I cut - for example - 3mm MDF without PPI I can do this at 15 mm/s and 50% power with a 60 watt laser. Switch on PPI at 350 ppi with 99% power and 15 mm/s and it won't cut through it. I have to drop the speed to about 5 mm/s.
Any ideas what could be causing this? PPI doesn't seem worth it. I'm using the latest versions of the software as far as I know.
LaserCAD 6.88B
131210V678 of the firmware
Regards
Ryan
