Wiring diagram
Posted: Sun Jul 20, 2014 8:43 am
by WoodChucksCNC
I have started the wiring on my new machine and I am looking for the wiring diagram between the DSP the driver and the motor. Here is what I have.
3 phase motors with 3 wires and 3MD560 Leadshine 3 Phase 8.4A 1-axis Stepping Motor Driver.
The motors are what came with my 1200x1800 stage.
I have been looking through the forums and haven't found anything.
Thanks for any help
Re: Wiring diagram
Posted: Sun Sep 14, 2014 11:07 am
by Marentec
I have a similar problem
Bought a 6040 stage and 3MD560 in August
I am stuck , waiting for wiring diagram between the motor (6 wires) and the 3MD560 (3 pin output)
Re: Wiring diagram
Posted: Sun Sep 14, 2014 11:54 am
by NickWL
I just Googled "3MD560 wiring" - it seemed to provide the answer you're looking for.
I think
Re: Wiring diagram
Posted: Sun Sep 14, 2014 12:04 pm
by cefs
The enables ENA- and ENA+ are left disconnected. PUL+ and DIR+ are wired to +5 volts, PUL- and DIR- are connected to DSP. The 3 motor connections are any way you wish, you may need to swap a pair to get the motor to move in the right direction, trial and error. See my post below '60w power supply', asked the same question. Marco has a wiring diagram for the AWc608 if thats what your using.
Re: Wiring diagram
Posted: Sun Sep 14, 2014 1:29 pm
Sorry for the confuse, I will post the connection of the 3phase motor soon. It used to come with 3 wires U, V, W
But now, it comes with 6 wires. We need to pair it up and make it up to 3 wires
Re: Wiring diagram
Posted: Wed Oct 01, 2014 7:17 pm
by JorpJomp
I am having the same problem. I am not sure what you mean by " We need to pair it up and make it up to 3 wires"
Having good luck getting out machine we ordered last month put together, way more intuitive than a home build cnc we ordered a few years back from another company, but we finaly seem to be stuck.
We aren't pros are reading diagrams, can you tell us physically what wires connect together in what order? and then hook up to the 3MD560?
Re: Wiring diagram
Posted: Thu Jan 22, 2015 5:13 pm
by thejuggernaut
So I think I understand. I got out the multimeter and checked for continuity, and when I get a circuit, I pair those two wires up and stick them both in the same connection. Either U, V, or W.
