very hot Stepper motor even when stopped
Posted: Wed Jul 16, 2014 7:19 am
by 1n2
Hi Guys
Been out of here for quite a while...
Still having 'fun' issues though
..... I will come back to the other issues in another post.
I often have to re-align the beam ( vibration I imagine) well this time I discovered the x axis motor is getting almost too hot to touch and this is with machine standing idle...all settings in the drivers are the same for the X and the Y ...anyone offer any suggestions??
John
Re: very hot Stepper motor even when stopped
Posted: Wed Jul 16, 2014 8:35 am
If you're having 1A or above setting on the motor driver, put it down to 0.6A or so. Also, make sure you use "Half current" on the driver setting. When a stepping motor is not spinning, it need current to hole the brake to stop the shaft, just like holding a brake on a car
(in China)
Posted: Wed Jul 16, 2014 11:34 am
by 1n2
Tech_Marco wrote:If you're having 1A or above setting on the motor driver, put it down to 0.6A or so. Also, make sure you use "Half current" on the driver setting. When a stepping motor is not spinning, it need current to hole the brake to stop the shaft, just like holding a brake on a car
(in China)
Thanks Marco
I will check that ...although the Y axis one stays cool with same setting?
John
Posted: Wed Jul 16, 2014 4:42 pm
The motor Y is different. It taks 0.8a to 1a depends on the model. That's why it stay cooled when idling.
Posted: Fri Jul 18, 2014 9:46 am
by 1n2
Thanks Marco
That's done the trick..if I didn't have to keep re-aligning the beam
I would never have discovered that!!
I shall be moving soon and I hope to have a larger workshop and am looking closely at one of the 900 x 600 XY stages kit.
John
Posted: Fri Jul 18, 2014 9:59 am
FYI, a stepping motor can sustain temperature up to 80'C before it is getting de-magnetized. So, avoid to have stepping motor temperature go over 80'C
I'm working on a new shipment of 900x600. The departing date is scheduled sometimes on next week and it will take about a month to reach our warehouse in California
Plus, a new design of power Z table (600x400) is completed and 30x unit will be shipped alone with the same shipment.
