Cut Parameters question Max/Min power 1/2
Posted: Wed Apr 02, 2014 9:09 am
Hi,
I have a laser at home that only has 1 power setting per layer. Circles slow the head down and there is no adjustment.
LaserCut5 had 2 power settings per layer. One for line and one for curve. I always just set them both the same and never had any problems.
LaserCAD has 4 settings and the manual covers an older version that has different options so I'm not sure how best to treat this.
Can someone explain these 4 options and maybe provide an example of what I should be putting in there.... I'm assuming one of these is for curves but it seems like maxpower should be the curve and minpower be the line. And in that case what is #2??
