not new but still exist
Posted: Fri Feb 28, 2014 11:01 am
by waltfl
hi marco
did you ever find a solution for my problem that the power setting always changes two fraction of a percent from setting in lasercad v. 6.81 to the machine?
it gets annoying, every time I set the power for instance to 11.00% IT CHANGES AFTER DOWNLOADING TO THE MACHIONE TO 10.80%
ALWAYS POINT TWO PERCENT.
I appreciate your help
Re: not new but still exist
Posted: Fri Feb 28, 2014 12:27 pm
Sorry I can't duplicate your problem. What is the version of the LCD? I remembered that I offered a new chip for the LCD unit and the new patch on the chipset allow 0.1mm movement instead of 10mm before. So, is your LCD can handle at least 1mm movement? If it is not (means that min. step is 10mm), then you need to upgrade your chipset
Posted: Fri Feb 28, 2014 1:32 pm
by waltfl
Hi marco
sorry I must have mist this.
my system version:
board 7.13.12.10
LCD 5.12.02.29
how to order the new chip???
please let me know
thanks
Tech_Marco wrote:Sorry I can't duplicate your problem. What is the version of the LCD? I remembered that I offered a new chip for the LCD unit and the new patch on the chipset allow 0.1mm movement instead of 10mm before. So, is your LCD can handle at least 1mm movement? If it is not (means that min. step is 10mm), then you need to upgrade your chipset
Posted: Fri Feb 28, 2014 4:13 pm
Walt, your chip is updated so no need to buy the chip
I thing it is the LCD unit issue. "0.2%" is really nothing to worry. Just live with that. Not worth to spend $85 for the LCD control unit
Posted: Mon Mar 03, 2014 1:49 pm
by Whiteylightning
The work around seems to slap me in the face. If the dsp ALLWAYS decreases by .2 % just input what you want the power to be plus .2% and your problem should just wash away.
