DSP changes power after loading
Posted: Tue Jan 21, 2014 11:44 am
by waltfl
hi
here is a new one.
since about a week every time I load a file in the machine the dsp changes the power level on its own.
for instance : I load with 11.2 % power it goes in the display shows for a second the 11.2% but changes right a way to
only 11%, or I load with 10.6% it changes to 10.4% and so on.
does anybody else have experienced something like this?
maybe marco can talk to the programmer and ask what is going on why it does this.
Re: DSP changes power after loading
Posted: Tue Jan 21, 2014 12:36 pm
Can't get a hold to the programmer for the next 2~3 weeks as Chinese New Year is coming and everybody is heading 'HOME'. The whole nation will take a long break, possible 2 weeks in general
What version of OS you're using? The latest one I sent you, V13120?
Posted: Wed Jan 22, 2014 1:59 am
by waltfl
hi marco
thanks for the fast respond yeah I did not think on the holliday . no problem .
the version 13120 comes back as "no upgrade" I don't know why, I try many times with new formatting the stick and reloading the upgrade always the same.
I am using the previous version.
Tech_Marco wrote:Can't get a hold to the programmer for the next 2~3 weeks as Chinese New Year is coming and everybody is heading 'HOME'. The whole nation will take a long break, possible 2 weeks in general
Posted: Wed Jan 22, 2014 11:29 am
Couldn't upgrade??
It couldn't read the memory stick in most case. You may want to to reformat it to FAT32
And if you can, always use 2GB or 4GB to do the job. Sometimes you may want to download the file again as it could be corrupted.
Posted: Wed Jan 22, 2014 11:55 am
by waltfl
hi marco
I used a 128Mb stick and have format it a few times with FAT 32 and reload the upgrade but I can not find the link for downloading the upgrad can you send it again please
Tech_Marco wrote:Couldn't upgrade??
Posted: Wed Jan 22, 2014 11:58 am
Check your email, link sent.
Not sure if 128MB memory stick work. The best is 2Gb or 4Mb
Posted: Thu Jan 23, 2014 2:41 am
by waltfl
thanks marco
the 128mb did work with the otherosupdates but I will try a 2gb
Tech_Marco wrote:Check your email, link sent.
Posted: Wed Jan 29, 2014 2:13 am
by waltfl
Hi marco
no it does not work I try a 1Gb, 2Gb and 4Gb sticks all brand new format them with FAT 32 and copy the OS update v. 13120 but all of them now says no usb stick, what is going on??
please help
thanks
waltfl wrote:thanks marco
Posted: Wed Jan 29, 2014 1:45 pm
The USB port could be dirty or lose. Try if you can read other file when saved a work file in the memory stick
Posted: Wed Jan 29, 2014 2:35 pm
by waltfl
hi marco
yes all other files from other sticks working
Tech_Marco wrote:The USB port could be dirty or lose. Try if you can read other file when saved a work file in the memory stick
Posted: Wed Jan 29, 2014 3:26 pm
Did you check the hardware version you have? V6, V7, or V8?
If version is correct, then the file you downloaded could be corrupted
FYI, sometimes you need to cycle On and Off of your machine in order for the DSP to read the memory stick
