LSR-JN100W-2V
Posted: Sun Nov 24, 2013 5:20 am
by Dion
Hello Marco
This is the current description:
Key Features of the JLD100W CO2 Power Supply
This power supply ideal for 100W~120W Co2 laser. Built-in PWM control and analogy power control. It works great with Reci W4 & W6 laser tube.
PWM control
Very stable output
Both TTL and Analog Power Control
6 hrs full power burn-in test
Specification
Input: AC220V, 50/60Hz
Power: 100W~120Watt
Triggering Voltage: 40KV
Operating Voltage: 22KV
Current: 32mA
Dimension: 9"x12.5'x4.5"
Note: No power cords are included; as it's used 'inside' of the machine. The manual is available from the Support Site.
Do I need to add HV cable (LSR-HVCBL) and Silicon Flex Tubing (LSR-WTUBE6X9) or are they included?
Re: LSR-JN100W-2V
Posted: Sun Nov 24, 2013 6:34 am
No, you don't need to order separated as it is included
