future update request adding a USB stick or HD as memory
Posted: Tue Sep 17, 2013 2:21 am
by waltfl
Hi marco
I was taking to a engineer from texas instruments ( the maker of the DSP chip) in regards to some features and he recommended that the software could be changed the way that a external USB stick or HD would be used like in computers RAM extension.
could you ask the programmer if this could be done with a OS upodate??
thanks
greetings waltfl
Re: future update request adding a USB stick or HD as memory
Posted: Tue Sep 17, 2013 2:56 pm
What is the purpose to do it? The USB port for the memory stick already serve the purpose, isn't it?
Posted: Tue Sep 17, 2013 3:04 pm
by waltfl
hi marco
no the port is just used as a memory for file storing but the program does not use it as expansion for the working memory like a RAM extension in a computer where the main OS extends automatically to a hard drive area. for some files the 64Mb are not enough for the mathematic calculation of the DSP
Tech_Marco wrote:What is the purpose to do it? The USB port for the memory stick already serve the purpose, isn't it?
Posted: Tue Sep 17, 2013 3:18 pm
Oh. so you means to have extra RAM for the DSP chipset to process data? Hmm... it sounds interesting. Let me see if I can get a hold with him tonight. I'm not sure if he is willing to do it because any change on the hardware is a major upgrade. Need to redesign a new board, PCB it, sample it and then mass production. If he is willing to do it, then I have to name the DSP to another, could be named "LO609" :lol:
Posted: Wed Sep 18, 2013 1:38 am
by waltfl
Hi marco
like the engineer said I am not such a expert, but he said that the existing DSP can handle way more RAM and to use a USB stick or HD is just changing the base routine. No changing the existing hardware required.
Tech_Marco wrote:Oh. so you means to have extra RAM for the DSP chipset to process data? Hmm... it sounds interesting. Let me see if I can get a hold with him tonight. I'm not sure if he is willing to do it because any change on the hardware is a major upgrade. Need to redesign a new board, PCB it, sample it and then mass production. If he is willing to do it, then I have to name the DSP to another, could be named "LO609" :lol:
