"Engrave beyond size!"
Posted: Tue Jun 11, 2013 7:51 am
by abdo
Hello Marco!
I just finished my conversion and am very happy about the speed!
I still have a little issue: After uploading a new file, it's partially engraving and then I'm getting "Engrave beyond size!" on the LCD panel. It's not a big engraving (around 6x6 cms) and my range is 300x200 . How can I fix this?
I have tried with different engravings. The file that was originally on the machine (Donald duck) engraved just fine although it was bigger.
Re: "Engrave beyond size!"
Posted: Tue Jun 11, 2013 10:08 am
Check out this post:viewtopic.php?f=8&t=1619
Marco ;)
Posted: Wed Jun 12, 2013 1:42 am
by Sesijama
Hi
I have same problem. Iget error "Engrave beyond size!" every time i push "Start" button.
Everything is set as in the topic you post here.
Any idea???
Posted: Wed Jun 12, 2013 7:06 am
by abdo
Thank you, Marco =)
I played around with what you told me and also changed the Origin mode to soft mode. The latter seems to have helped :-)
Posted: Mon Jun 17, 2013 1:52 am
by natsterrr
abdo wrote:Thank you, Marco =)
This worked for me also.
Just a note: after checking every part of lasercad I finally realised that you set the soft origin mode on the DSP control panel!
Hope this helps :)
Posted: Wed Feb 19, 2014 8:53 am
by ArmandoMEX
It also helped for me, although I haven´t figured why my origin should be set to Right UP and then LaserCAD changed it to Left DOWN by itself. Any other setting won´t result into engraving and show Engraving Beyond Size. But finally it is working now. Thanks for the support MARCO!
Posted: Sun Jul 20, 2014 3:22 pm
by Ihrke052
I seem to be getting this error as well. Earlier today it would run about half of a job and then give me the error. Now it is having the error as soon as I hit start. I have the origin set up and top left (havnt changed it since I got it going a year ago) and have the LCD controller set up with soft control (theses settings also haven't been altered ever).
Any thoughts why this is happening? I put my laser project on hold for 6 months and now I seem to have an error even though nothing had changed from then until now, it simply didn't run for a while. I can still run old jobs from 6 months ago that are stored on the LCD controller but any new jobs I attempt to run have this error.
Posted: Wed Jul 23, 2014 12:34 am
Zoom out the work space see if any drawing even a 'dot' draw outside of the workspace. Also, check the "Position Relatives" see if it match the limit switch setup
Posted: Tue Jul 29, 2014 6:29 pm
by Ihrke052
I was able to get a new file to work from the start by moving it a few inches away from the edge of the working space. Is there any way to avoid this? The reason I ask is because it makes aligning the piece to be cut/etched more difficult. If not is there a general amount of space I can always bump my artwork in that will avoid this happening?
Also when this happens in the middle of a job is it being caused by something different? Seems like if the job is going smoothly it shouldn't suddenly be stopped (when the job was prepared I had plenty of space left before an edge)
