Open multiple files in lasercad
Posted: Thu Jan 31, 2013 10:29 pm
by tech_builder
Is it possible to open multiple files in Lasercad at the same time? This would make it possible to open a dxf file for cutting and an image file for engraving on the same screen and lay them out appropriately.
thanks
Re: Open multiple files in lasercad
Posted: Thu Jan 31, 2013 11:20 pm
You may import different file into LaserCad and use layer to separate it. To enable the layer, just put a check mark on the laser. To enable multiple image, put a check mark on "Reserve the current document" and it will allow multiple images to be imported
Posted: Fri Feb 01, 2013 11:05 am
by tech_builder
Thanks! I didn't see that! It is exactly what I was looking for :)
Posted: Fri Feb 01, 2013 12:13 pm
by waltfl
hi marco
now I am not sure where can I find this " reserve the current document" and where to put the checkmark on the laser??
thanks
Tech_Marco wrote:You may import different file into LaserCad and use layer to separate it. To enable the layer, just put a check mark on the laser. To enable multiple image, put a check mark on "Reserve the current document" and it will allow multiple images to be imported
Posted: Fri Feb 01, 2013 12:21 pm
When you're doing image importing using the "Import" feature by clicking "File"
The option is right at the bottom of the pop up screen
Posted: Fri Feb 01, 2013 12:30 pm
by waltfl
Hi marco
thanks , I never look down there.
did you find out what the chinese language stuff means in the new lasercut manufacturer settings means???
thanks again
Tech_Marco wrote:When you're doing image importing using the "Import" feature by clicking "File"
Posted: Fri Feb 01, 2013 12:32 pm
You lost me. Where is it?
Posted: Fri Feb 01, 2013 12:59 pm
by waltfl
hi marco
its this here see attachement
ote="Tech_Marco"]You lost me. Where is it?[/quote]
Posted: Fri Feb 01, 2013 3:16 pm
by Greolt
In the above posts I see LaserCad 6.35 and 6.37.
When did these releases happen? How do I get the latest?
I am on 6.27
Greolt
Posted: Sat Feb 02, 2013 11:16 am
Sharp eyes! Yes, the latest is 6.46. There is not much change on the software per programmer. One thing he did was to fix the Chinese characters showing up on Win7. Also, a minor fine tune for big machine that use for cutting. So I didn't post it yet.
