U axis for rotary?
Telrad
U axis for rotary?
Post by Telrad »
Is it possible to use the U axis for rotary engraving? I have more than enough motor controllers in my setup and it would be very convenient. I wouldn't have to keep switching motors or wires to make it work.
Greolt
Re: U axis for rotary?
Post by Greolt »
I am replying, not because I have a good answer for you, but nobody else has.
No you can not use the U axis for rotary, only X or Y. With Y swapped to A, being the most common configuration.
Greolt
Telrad
Post by Telrad »
That stinks.
Post by waltfl »
Hi there
now I am baffled because the Z is for a lift table and the U is for rotary acessory in acordance with the manual of the AW608
if there is something new???
Greolt wrote:I am replying, not because I have a good answer for you, but nobody else has.
Greolt
