erroneous measurements
Posted: Thu Oct 11, 2012 3:23 am
by Javier
hello good morning, my problem is that awc 608 lasercad or not recognized measures in millimeters. I have to do a conversion or rule of three millimeters adjusting the measures of the machine, which are these conversions: 100mm are 58.82 in lasercad, 170mm are 100 in lasercad, and so I always cut something in the machine, which give me solution?
Re: erroneous measurements
Posted: Thu Oct 11, 2012 5:05 am
by waltfl
Hi javier
this is a probleme with adjusting the machine with a test square .make a square in laser cut set it to cut 15% and 80mm/s speed then cut it
then follow the picture
Javier wrote:hello good morning, my problem is that awc 608 lasercad or not recognized measures in millimeters. I have to do a conversion or rule of three millimeters adjusting the measures of the machine, which are these conversions: 100mm are 58.82 in lasercad, 170mm are 100 in lasercad, and so I always cut something in the machine, which give me solution?
Posted: Thu Oct 11, 2012 3:03 pm
by Javier
Thank you very much Problem Solved
