Connecting AWC-608B DSP and TB6560-4V5
Posted: Mon Oct 01, 2012 2:15 pm
I'm starting to do all the wiring for a 40W buildlog.net Laser. I purchased a AWC-608B DSP and TB6560-4V5 from LO.
I assume I've got to hook into the controller parallel port pins to the DSP. I think I've got everything figured out except the DC5V. Do I need to connect the DC5V for X/Y/Z or will just the STEP / DIR be enough? If so can I just feed the DC5V from someplace off the DSP?
Here's the plan:
Thanks for the help,
Mike
Here's the plan:
Code: Select all
TB6560 parallel port DSP
???? > X-DC5V
PIN2 > X-PUL
PIN3 > X-DIR
???? > Y-DC5V
PIN4 > Y-PUL
PIN5 > Y-DIR
??? > Z-DC5V
PIN6 > Z-PUL
PIN7 > Z-DIR
Mike
