100W-200W CO2 Sealed Laser Tube Dimensions (JLD100W)
Posted: Tue Sep 04, 2012 6:10 am
by tbecker
Does anyone has any detailed drawings for the 100W-200W CO2 Sealed Laser Tube? Model number JLD100W
I would be even happier to have a 3D solid model.
Thanks.
Re: 100W-200W CO2 Sealed Laser Tube Dimensions (JLD100W)
Posted: Tue Sep 04, 2012 7:09 pm
It's not easy to tell exact dimension of a laser tube. Laser tube coming from different manufactures more or less are having size discrepancy , even the same model! However, to build a laser machine you don't need an exact dimension of a laser tube. It's always require to leave some room for the tube in all aspect (Left, Right, Top, bottom). Most laser tube mount is adjustable for fitting a tube with different diameter.
Posted: Wed Sep 05, 2012 1:13 pm
by TeacDance
tbecker wrote:Does anyone has any detailed drawings for the 100W-200W CO2 Sealed Laser Tube? Model number JLD100W
Thanks.
Why do not you draw it yourself? Marco can perhaps give the dimensions, because sleeping on top of them
. If you do not draw it so yes I can draw it for you if you need help.
lightobject online store that can be found in the basic dimensions of the tube
Specification
Power: 100W
Triggering Voltage: 30KV
Operating Voltage: 22KV
Current: 28~30mA
Life Span: 3000~4000 hrs
Length: 1650mm
Diameter: 65mm
