operate 2 relays at once?
PowerRacerRC
Post by PowerRacerRC »
I cannot trigger 2 relays at once... I need to do this in order to drive an RC car forward and steer at the same time...
Any way to do this from one remote? Use 2 receivers?
I think if I use 2 receivers, the second will just trip the first signal and not respond to the left/right commands... Any way to cut out the signal I want it to ignore?
Does the controller even send out 2 signals? If it can only do one at a time there is no way to do what I want... :?
Re: operate 2 relays at once?
Unfortunately, there is only one relay can be triggered per location, even though you may have 2 or more controls set. The Encode/Decode doesn't help as they share the same frequency which is 433MHz. Unless you switch to another frequency, otherwise there is no solution
