LaserCAD bug: BMP layers not working properly
Posted: Mon Jun 04, 2012 3:26 am
Hey guys, well, I am finally getting grips on my machine now!
However, there is 1 problem that I can't seem to figure out!
When I import an image to raster, the X axis never moves! On my machine, the Y axis is the one with the card + laser lens.
So the Y works fine, but all it does is just draws a single line!
This only happens with BMP layers though. If I draw a normal shape and set it to engrave, it works fine. If I put in an image and put it's settings to the exact same, the X axis doesn't move!
Note: If I set the BMP layer to X swing, it works fine, but doesn't work on Y swing!
Tried it on multiple machines, and it doesn't work with Y swing on any of them.
Dan
Dan
