PTC Temperature sensor for JLD612
Posted: Tue Mar 13, 2012 11:48 am
Hello
I new here and new to PID control and temperature measuring. I hope my question are too far off base.
I have a temperature sensor identified as a PTC (1000 ohm @ 25C). Based on google / wiki research that is not a typical temperature sensor.
Question: Can the JLD612 accept this input and what settings would I need to change.
The application is a water bath hold in the range of 120F - 170F with step changes in the 20F range. (Beer brewing to be a bit more descriptive)
I would like to have tolerance in the 0.5F range, but its not real critical.
If this sensor won't work or if the JLD612 is not the correct controller, can you suggest a combination that would work.
Thanks, David
Thanks, David
