Jld 612 - insane readings and rapid changes...
Posted: Sun Mar 04, 2012 10:05 am
...usually when al1 and al2 toggle on and off.
I have the controller fitted with a pt100 probe (set for p10.0 or p100). Its wired to an outlet according to the SSR setup from the manual. There are also a couple of uncontrolled outlets that remain on. The only modification that I have made is to add a wire from the shielded thermocouple cable to where the second blue thermocouple is connected
Everything will function fairly normally, I believe, until the al1 and al2 lights click off and the readings go haywire. The reading will sometimes change 400 or more F and stabilize until the lights click back on Should these lights even be on for me?
Here is a Video of the Problem: http://www.flickr.com/photos/75833803@N ... hotostream
Thanks for any help!
