Wavy Cuts and Bad Etching
Re: Wavy Cuts and Bad Etching
Hello:
Since you have tried many things and the problem still not being able to solve the problem. Please return the DSP for troubleshooting.
Return address:
21 Blue Sky Ct. Suite A
Sacramento, CA 95828
Attn: Marco Wong
I need your order# and to get your a RMA#
1n2
Post by 1n2 »
Hope I am not butting in here
But I had a similar issue a while back drove me mad looking for bad connections etc.
Mine turned out to be the lens moving in its holder...a quick refit solved it !
John
Post by baccus61 »
Sorry for your trouble. Have you tried to run the file again right over the top of the first one to see if the wavy lines are the same or does it follow the same path as the one before. Is it repeatable?
proper grounding is a common issue with laser too. (but I think not in this case)
How did you get on?
