i tried installing it again, now it tells me it cannot find autocad? whats up with that?
thanks
my 40W 2012 DSP conversion
concretevapor
Stephen6309
Re: my 40W 2012 DSP conversion
In the AWC-608 manual, page 62, shows that you need to run the AWCLaserCut.AWC_Init macro to get it to show up.concretevapor wrote:thanks Stephen6309.
i went forth with the install but, still cant seems to see any trace of a plugin interface when i turn on autocad.
abdo
I had the same problem with Corel: the issue was that I had an older version folder still in program files. Go to program files or program files x86 if you're using win7 or 8, locate the old installation directory and see if the macros have been placed somewhere there. In my case (for Corel) it was under draw/GMS/
I copied the file to the new Corel directory and loaded it from the application.
I hope this helps =)
