20W Fiber Optics metal engraving machine cutting capability
swamidog
Re: 20W Fiber Optics metal engraving machine cutting capabil
Post by swamidog »
NickWL wrote:I remember building high-speed mirrors in the late 1960s for use in 'light machines' in clubs and discos. We made them far more precise than necessary - but the were far better than today's feeble efforts (and far more expensive!)
Nick
yeah.. i use galvos in the laser projectors i build and use. same idea. ;)
MitchL
Post by MitchL »
Tech_Marco wrote: I'm getting a quote for the 100W, 300W, and 500W laser module. I may come up my metal cutting machine that is capable to cut up to 5mm thickness stainless steel in one pass!
If you're serious and can do this, I'm in. A metal cutting laser in my shop would be absolutely awesome.
We'll need gas assist, right?
/Mitch.
Mitch:
How thick do you want to cut? Stainless steel or iron plate?
Nitrogen or CO2 air assisted seems help. I got to find out more about it
NickWL
Post by NickWL »
I'm guessing the laser unit could be mounted to an x-y gantry at which point the expensive servo system would not be needed.
Might not be quite as fast, but I wold happily trade speed off to save on capital outlay.
Nick :?:
Nick:
For cutting, we don't need speed. If one can do stainless steel with 10mm/s is considerate as high speed. Sure we can take advantage from high speed cutting (not really doing cutting but engrave the outline of characters graphics). In that case, 200mm/s sure be considered as fast enough. Most XY stage can handle up to 500mm/s. So, speed isn't our concern but the price of the laser module and the controller card.
Return to “Metal Cutting/Engraving laser machine”
