Page 10 of 15
Posted: Mon Oct 01, 2012 12:09 pm
The 40~60W PS is OK to the laser tube. As long as current is limited to 18mA or below, it works fine. But if you really want to use 40W, then you may need to wait for a while as a model of 40W will come in about 2 weeks. FYI, most manufacturer are trying eliminate the 40W as cost wise, both 40W and 60W are very closed and the 60W just work fine for a 40W laser tube.
Are you looking for 110V or 220V? I may have a couple left over. I got to check
Posted: Tue Oct 02, 2012 5:58 am
by Myke
Thanks. I wait while the DSP and TB6560 arrives. Now I am unsure which laser PS will I use. Maybe I will try to make it working with the original supply.
Posted: Tue Oct 02, 2012 10:31 am
Send me some pictures of the original power supply. If you can, take picture from inside out. Also, I need to see the connection terminals. The DSP may work with your original PS
Posted: Wed Oct 03, 2012 3:40 am
by Myke
Tech_Marco wrote:Send me some pictures of the original power supply. If you can, take picture from inside out. Also, I need to see the connection terminals. The DSP may work with your original PS
I made 3 picture. Let me know if any other pictures needed.
https://dl.dropbox.com/u/67125876/x/laser1.jpg
https://dl.dropbox.com/u/67125876/x/laser2.jpg
https://dl.dropbox.com/u/67125876/x/laser3.jpg
Posted: Wed Oct 03, 2012 12:10 pm
by waltfl
Gi myke
from experience I would not use the old laser powersupply because its analog and you can not use some feature from the DSP.
Myke wrote:Thanks. I wait while the DSP and TB6560 arrives. Now I am unsure which laser PS will I use. Maybe I will try to make it working with the original supply.
Posted: Wed Oct 03, 2012 1:16 pm
by chakata
My recent experience is that we were unable to connect the new bits to a similar power supply. Recommend that you get a compatible PS from Marco. At least that way all the connection terminals are marked in a way you can understand and ordering now will get you going just that little bit quicker lol
Posted: Thu Oct 04, 2012 6:28 am
by Myke
Posted: Thu Oct 04, 2012 9:33 am
by pannaus
We finally managed to do all the connections.
But now the machine doesn't power up. Actually it's a problem of the power supply. It won't switch on. It's set on 220v (that's the sign we see on the red switch) and we tried even to connect it directly to the power cable bypassing the power on button.
Nothing happens. THe fuse is in place and works (we tested it), but the fan and the led don't turn on.
So...what do we do?
Did we buy a broken power supply?
Posted: Fri Oct 05, 2012 6:36 pm
It's hard for us to tell what went wrong if you didn't provided more info like connection diagram, pictures of your setup...etc.
One thing you may forgot to do is to connect the "WP" to the ground to enable the Laser Power Supply.
If the power supply comes with a 'test' button, you can test the beam by press down the button. It should output 20% power
Posted: Sat Oct 06, 2012 8:58 am
by pannaus
Marco, I must tell that the conversion does not require a bit of knowledge about wiring and such. it requires A BOATLOAD of KNOWLEDGE
Now, we got the ps to work, even though the fan does not turn on.
The display turns on, as both DSP and 24V power supply do.
The tweaking will take quite a bit. Also, a lot of things where hard to understand and find.
A better diagram of ALL the connection would have helped a lot.
Anyway, the fan works if connected to batteries, but it does not work when connected to the power supply.
The arrows on the display make the bars move, but we keep hearing a whistle coming from the motors. Also, the motors do a very ugly sound when moving...
There's a bunch of stuff that needs to get fixed in order to have a smooth working machine, but I'm afraid this forum does not deliver all the info it should. This could easily be fixed with a better connection diagram and a manual about converting the K40 to a new DSP machine.
Just a suggestion.
Posted: Sat Oct 06, 2012 10:51 am
It's not about the K40 machine, it's about the understanding of the DSP , the stepping motor driver, and the knowledge of the pulse unit concept. The K40 has no difference than other laser machine. It's just a smaller machine and it require the same setup as other laser machine.
The issue you're having is the concept of connection the knowledge of the DSP. I do have connection diagram to the DSP posted. I don't think that I have to post the diagram to a specific machine regardless K40, 1080, 1020... As I said, they're the same. The difference is the size of the chaise, the size of the stepper, current handling of the motor driver, the power rating of a laser tube... So, you got to understand the
See this post:
viewtopic.php?f=55&t=660
Even though it's not exact for the AWC2012, but the concept is identical.
The reason you have hard time to move the motor or the motor sounds squeeze. It's because the setup of the "Distance unit per pulse(um)" was not setup properly. That's why I asked you to send me the picture of the your system so we can see what driver you're using and what setting on the stepping motor you're using. Without proper setting of the (UM), your machine will never runs smoothly or moving at all.
If you download the manual of the DSP, you should read the manual as it should cover how to use the 'calculator' to find out the pulse unit
Posted: Sat Oct 06, 2012 10:53 am
Here is manual and the basic connection diagram:
viewtopic.php?f=16&t=938
Posted: Sat Oct 06, 2012 11:01 am
by pannaus
Yes, and I think the problem is "basic". I think it should be more detailed. Talking about the diagram
Posted: Sat Oct 06, 2012 11:23 am
When I got spare time, I will make a "real" connection diagram. Now, I`m all booked.
Posted: Sat Oct 06, 2012 11:59 am
by pannaus
Thanks man
