Got it, thanks.
Bob
XLE steppers locked up when powered?
lauckstreet
lauckstreet
Re: XLE steppers locked up when powered?
I made those changes from negative to positive but it still is moving in the wrong direction.
Where should zero be on both axis? Upper left, upper right, lower left or lower right? Based on where the homing switches are, it appears to be upper right corner. So it that's zero, then down should be y+ and left should be x+. When I move the x axis in the +direction, it moves right, not left. When I move y in the +direction, it moves to the back of the frame towards the laser tube, not to the front of the frame.
What am I missing? I can't seem to reverse the direction of the movement either from the controller pad or LaserCAD.
Bob
Bob
The HOME could be any corner. To make the change in effect, you must hit "RESET" on the LCD control panel after saving the change
