need help. not enough RAM
lanoph
Hello,
i got used to engrave choco-sweets like M&M´s and so on. So therefor I have a special part where I can put ca. 280 M&M´s in and i have to start the engravingbutton (Process) at my software to engrave all 280 M&M´s at on time.
I´made an schematic at Corel, put in only one time the Stuff i want to engrave and the start the VBA-Plug-In to fill out all the M&M-Places at my Board.
Now, since I have the new Mainboard / Card from lightobject.com I can not engrave the M&M´s because every time I start the process-Button ist start to say: "Processing..." and after a sertain time it says "drLsRun has not enough RAM.
I tried to engrave only one line, but it also does not work. Does anyone has an idea, what else I can do?
Thanks a lot.
CL
Thanks a lot.
CL
twehr
Re: need help. not enough RAM
This is a computer RAM issue, not a controller issue. You need to install more RAM memory on your computer. I don't know what you have, but 2 gig is enough for a lot of jobs, but 4 is much better. I run 4 and have never found a job that it cannot handle.lanoph wrote:Hello,
Thanks a lot.
CL
lanoph
Hello Tim,
I tried it at differnet Computers and I still have 4GB RAM.
It also worked with the same picture befor, when I had the Old Mainboard.
I couldn´t get it run. But when I Export the Corel-File to AI and than import it at RLaserCut everything is working good. But normaly I don´t want to do it every time I wan´t to engrave something.
Does anyone has another Idea?
Thanks for your help.
Christoph
Christoph
Are you using our software that I posted over here or your're using your own software that worked for the old card?
lanoph
I´m using the software you posted here, but what i want to say is, that the same file, with the same data, could be engraved before, before i changed the mainboard.
Christoph
Christoph
twehr
Are you having CorelDraw do the rows and columns or are you having the RLaserCut software do it? You should be having the RLaserCut do it.lanoph wrote:Hi Marco,
Christoph
twehr
Send a copy of your file and I will try it, if you wish.lanoph wrote:Hi Marco,
Christoph
lanoph
Hello Tim,
I used the corel-Draw to make the rows and the columns, becaus i cuttet tho board, where the M&M´s are in also with coreldraw. and i could use the corel-plug-in to engrave with all the data I created in corel. than i can also mix the different pichtures for engraving, when i want to make laike 200 different names, I don´t havt to wirte they all seperated, I can use a VBA in vorel to organice all the m&m´s. attached you can find the corel-file.
Black is the engraving
Yellow is the frame, that it fits in the Board with the holes.
Cyan is the cuttingway for the m&m´s.
Magenta is the row-direction for the seperated quaters / fields.
When i export the file as an AI or EPS at Corel and import it at RLaserCut it will work.
Thanks for the help.
- 101_m&m_Norbert.zip
- CDR is zipped because CDR does not work here in the forum.
- (62.24 KiB) Downloaded 259 times
twehr
I will try to get to it tonight and let you know. I understand, now, your reason for doing it in Corel rather than in RLaserCut.
twehr
OK, I tried your file and got essentially the same results as you did - not enough memory to handle the job.
I tried reducing the complexity of the job, but even removing all but one set (ellipse, rectangle, words) it was still trying to process something that is the size of the whole page.
I took one set, put in a new document, and replicated it. I noticed that as I copied and pasted, everything get pasted as groups. Copying several and pasting made even bigger groups, etc. Grouping adds a lot of complexity to the final output.
I removed all grouping from my file and tried - everything works perfectly. I did not get time to test the same on your file. I suggest you remove all grouping from your file and try again. Or you can use my file (see below) as a starting point and rebuild your setup. Either way, it is a bit of work to get set up, but I am confident the controller will handle your job once it is simplified.
I notice you called the candies M&Ms. The file you sent would be for candies much larger than traditional M&Ms. I am curious - what candies are you using? And what power setting are you using on what wattage laser? My 40watt at 20% (minimum I can go) and 400 mm/second just melts the M&Ms. I like the idea of what you are doing, but need some specifics so I can try it.
- MandM-TW.zip
- (135.95 KiB) Downloaded 226 times
lanoph
Hi Tim,
you are right. I don´t use the traditional MandM-Candys because they are not so large and i can not engrave so much text or massages on it. My board, where the Candys fit in are not only holes. the hole is getting smaler, when it is getting deeper, so I can engrave a lot different candys with different diameters.
I tried your file, but I have only CorelX3 running here. could you please save it as a corelX3-file-format, so I can try yours?
I have a laser with 50 Watt and I engrave the candys normaly with following settings:
Power1: 60 %
Power2: 65%
Speed: it depends on the deepnes I want: between 20 and 25 m/minute.
Attached you can find a foto of engraved Candys, but you don´t see it so good on a picture as in real.
Greetings.
CL
Power1: 60 %
Power2: 65%
Greetings.
CL
twehr
Here is the file in X3 (CorelDraw 13) format.
- MandM-TW-x3.zip
- (34.06 KiB) Downloaded 268 times
