language changed
Jacala
language changed
Post by Jacala »
Hello!
For some reason lasercad decided to change to chinese. Well to be honest I probably dis something without knowing it.
In the installation folder are language files so it would be quite simpel to change back to englisch but then ofcourse.... I do not speak chinese.
So,
How do I change lasercad back to englisch?
BTW: my laser had some basic maintenance done and with that I mean that it has been running a lot of hours without problems!
Maker23
Re: language changed
Post by Maker23 »
Here's where the menu items are, in my version of LaserCad:
Start the program, pull down the Options menu which is the 5th from the left ( File, Edit, Draw, Tool, Options, View, Help)
The first choice in the pull down menu is System Options, select that
In the right-hand half of the pop-up window, starting from the top, there are two items that take a typed number value and then a pulldown menu. This pulldown menu is the language selection menu.
My version only has four choices for language :) English is the third from the top.
