Received all parts and waiting for the tech to assemble it (in China). Should be completed in a week
*New* Handheld LCD control unit for AWC608 DSP
GiriPod
Re: *New* Handheld LCD control unit for AWC608 DSP
On Buildlog.net, you mentioned an additional cost of +$45 to upgrade AWC-608 LCD to handheld. Is this still true?
If so, can you put me on the list (if you have one) for an AWC-608 + handheld? I plan to replace a Leetro MPC6515 with it.
Sorry guys I didn't make a follow up message in time. Was very busy while I was in China. Anyway, 5 units should be recieved in about a week. I'll update you folks later
(returned home)
(returned home)
GiriPod
Any updates on availability?
GiriPod wrote:Hi Marco,
WoW! You got the six sense? I just received 3 units today and that's all I can get so far. The production was seriously delayed and it seems that the full production may take another one or two months.
Anyway, you can add $45 in addition and I'll upgrade the DSP with this handheld unit for you.
GiriPod
Thanks for the update Marco.
I have had a change of plan and can wait a few months until the unit is generally available.
nephertiti
Guldberg wrote: Will it work simulatious with the current control panel or is it a replacement (using the same pins)
Hi Marco,Tech_Marco wrote:
Can we use DSP LCD and handheld same time? I mean ; Can I connect lcd and handheld on same pins and both work sametime?
