LO chiller manual(2020)
chiller with JLD612 control
Note for December 2020 model(with blue light): SV is the temperature to cool down to.Do not use the instruction below to set temperature for newer model.
The Q800 and the Q1600 have the same layout.
LO-1600W Water Chiller instruction.pdf
(194.39 KiB) Downloaded 535 times
The Q1600 dual has the same water connection as the x2700.
LO-X2700 Water Chiller instruction.pdf
(187.34 KiB) Downloaded 225 times
Return to “Water Chiller”
