JLD612 wiring update...see if it's right?
robinhood
Just wanted to make sure that it's wired correctly now...
richiem
Re: JLD612 wiring update...see if it's right?
Looks OK to me.
robinhood
Thanks very much richiem! will give it a go.,..
chutney
thanks for putting up your drawing it helped me to lay things out right. The one thing I noticed is you put a fuse in the neutral back to the JLD612 post 2. I would never put a fuse in the neutral because you break the flow of power back to the box and you should only break the hot/positive. I finished my build last night and I'm running another test tonight.
