Still trying to figure this out...
Questions: I bought my X7 on the 4/11/2017, what firmware should be installed? Or is there a firmware upgrade available for this DSP?
Once again what's happening:
- I create a file in Raycam with the settings of MaxPower:80%, MinPower:75%, Speed: 25mm/s
- I Send (download) this to the X7 using Ethernet or USB (doesn't matter)
- When looking at the X7 Screen after download, the settings displayed on the screen are not the same...
- But, if I "Start" the job, it works fine... Speed, power, all ok
- If I try to go in and change the settings on the X7 to reflect what was sent, then if I run the job after those changes, the Laser is at FULL power no matter the what power setting I changed on the X7 using the keypad.
That's it so far, thanks to anyone who can shed some light on this.
![Smile :)](./images/smilies/icon_e_smile.gif)
