Grayscale image
samsieder
Grayscale image
Post by samsieder »
Hi.
When will you have an update for raycam or other software to use with LO-E5 for grayscale images ?
Re: Grayscale image
I tried the grayscale on X7 but I was not impressed by the result. May be I didn’t get correct image manipulation or what, the result look worst than just doing engraving with dithering. E5 runs on LaserCad and there is no “grayscale “ option from the drop down menu. Again, it didn’t work out good so far. May be it works on drawing but not an jpg image that I need to do more test next week
samsieder
Re: Grayscale image
Post by samsieder »
this is an image engraved with lo-x7. (greyengraved with a 0.04 gap)
Return to “DSP E5”
