I have finished my upgrade from stock K40 to X7 DSP with Z-Table, and all the little extras, thanks to everyone. I even made the first set of engraves, a project for my wife. That was some simple text on balsa wood. Simple design I created in RayCam.
Now on to one the things I want to do with it. I want to create PCB designs. I have the design in BMP format. I wrote a little java app to outline the traces, worked great. Now I want to load it into RayCam, so I imported it. I downloaded it to the DSP over COM port, I see the design on the screen. But when I hit start, I get an out of limit error. How do I fix that?
Can I set the origin relative to the image?
"Engrave Beyond Limit."
I have the um set correctly as well.
No matter where I move it in the drawing space in RayCam I get the out of limits. Its like 66 mm x 33 mm.
I even took the original trace BMP and used RayCams outline. Then deleted the original bmp. That works, kind of. I get the out of limits warning, continue? If I continue it draws about 1/2 of it on the left side of the work space. So I get the right 1/2 of the pcb engraved. The outline feature doesn't carve enough paint from the pcb.
Either way I've been looking to figure out how to set the origin relative to what I want to engrave. I have the 9 box set to the upper left and I see the blue dot in the upper left. I have my origin set to x = 0 y = 40, and even if I set the orgin on the machine to x=70, y = 40 it still goes back to the orginal location and engraves exactly the same.
Image out of limits
Mcaughey
Mcaughey
[Closed] Re: Image out of limits
Since Marco helped me on another thread I thought I would write up what was happening here.
I had read through the FAQ and missed understood a few things an we identified a few other things that should have were not in the FAQ but I should have set up right. You don't know what you don't know sometimes. I know now.
I did have the UM set correctly. That matters with this problem. um affects scaling.
1) I had Machine zero and page zero set to Upper left. You find both in the Menu > Option > System Options > Work space.
2) I didn't have the Relative Position set right, I had to change it to also be upper left. You find that Menu > Option > Relative Position.
3) I had set the X and Y range to 300 x 200 which is the work space for the K40. You do that in Menu > Option > System Options > Manufacture Parameters.
Now my work space matches the space in the K40. Engraving with precision is now possible.
Rdmcconnell
This is my problem!! Thank you for posting this update to your question!!
mrsunnylam
One time, I had clicked in an area far from my work piece(It left a dot), and the work space was stretched "OUT OF BOUNDS"
I had to learn the hard way
Users browsing this forum: No registered users and 18 guests
