coreldraw & ramcam to import
tehamatees
I am a Coreldraw user (x6) and I just downloaded RAYCAM. I am trying to import CORELDRAW files into Raycam and Raycam wont recognize them. What do I need to do to make this work?. I've used the computers and machines at L.O. Hq and there is a shortcut tab (top tool menus line) in their computer that jumps from Coreldraw to Raycam. What do I need to do to succeed?
Re: coreldraw & ramcam to import
Run the RayCam installation program and select CorelDraw add on module. Select the version and point to the correct path and that should take care it for you
Winstonc
I am trying to install the RayCAM plugin for CorelDraw X8 and after choosing the right version and directory it keeps comming back with directory not found. I have tried every combination I can think of with the same results.
Any suggestions?
David
Any suggestions?
David
So far both RayCam or LaserCad supports CorelDraw up to version 7.0 only
Will discuss with the programmer soon about the issue
Winstonc
Ok, thanks Marco
Winstonc
Does the plugin only work with the full version of the Coreldraw X7 or will it work with the Home and Student version? Just wanted to check before I buy.
David
David
Winstonc
I think I have answered my own question and the answer is it requires the full version to get macro support.
David
David
