K40 not cutting after x7 upgrade
custometching
Post by custometching »
I have completed my X7 upgrade and now it seems my k40 will not cut 3mm plywood. I have aligned it and have tried speed of 20 and power of 80 and it still does not cut through the plywood. Before upgrade it cut excellent. I am wondering if there is a setting in the new software I need to change?
Re: K40 not cutting after x7 upgrade
Use LaserCad, check the Max_power parameter. Also, check If 'PPI' is enabled or not. If In, the cutting power will be less but will reduce over burning on surface
custometching
Where do I find PPI in the software - max power is set to 98%
custometching
Ok I finally found the ppi - makes no difference if I have it enabled and set to anything or if it is off. Could my issue be my focal point distance?
custometching
What focus lense comes with the original K40? I know mine is smaller than the the diameter of the base it sets in with the new head that came with the kit.
custometching
Ok tried changing the height of my bed and it did not have any effect. Still same result. What next?
NickWL
Post by NickWL »
Original K40 usually comes with a 50.8mm (2-inch) lens. A useful, general-purpose lens.
Some people like to replace this with a shorter fl for engraving or even a longer one for cutting.
If you don't know any better then stick with the 50.8
:D
