In Lasercad 7.43 and 7.57, when selecting a color of a line, I cannot change the PPI setting. It's permanantly set at 200ppi and the box is greyed out.
What is the latest release of the software and where can we download the latest firmware for the AWC608?
Finally, Lasercad object selection has changed between 6.88 and 7.57. In 6.88, it was easy to select an object - you only had to drag the cursor box over the edge of an object to select it. This was a very valuable feature. Now in 7.57, I need to drag the box all the way around the entire object, which forces me to select anything that may be inside the object as well. Is there any way to change the way items are selected?
Thanks a lot!
Tim
Lasercad Latest Version and issues with ppi cutting.
wheelman
Re: Lasercad Latest Version and issues with ppi cutting.
Download the V7.60B of what I have enabled the PPI function. If you have other version installed, uninstall it and delete the folder before attempting for new installation.
Let me discuss the selection issue with Li see what he say.
I tried selection on V7.6 and I didn't see any issue that you mentioned. I was able to select part of an object and had it been selected. Or, I could just mouse touched the outlined and got the object selected. For all try, I didn't need to box the whole image in order to select it. May be I didn't get your point.
