JLD416PVA 150A : 5A Current Transformer Wiring
Posted: Fri Apr 13, 2012 2:49 pm
Hi guys,
I've been using your JLD416 Meter for a while now, and I'm finally going over 5amps. I'd like to wire the following transformer to it--pics below. Could you explain which wire goes to the top prongs? I see four in this transformer, so I'm no too sure of which wires from the meter wire to the top.
Looking at the directions, I see the load line going from 15 and 16 to the tranformer, and the 11 and 12 also going to the transformer. On the transformer I see S1-K, and S2-I, and the center hole has P1-K.
I'd guess that the Line(power) wire goes through the center, but the rest is more of a mystery to me.
On another note. Do I need to change anything in the meter? If so what number(s) would I enter?
SolarTony.com
SolarTony.com
