AWC/LO-X//Lasercad > can i increase power on the edges only
Posted: Mon Jun 27, 2016 11:10 pm
Hello,
i have problems with using cermark on my 40w laser. The edges can sometimes be washed off so i think it must be a problem with not generating enough heat since everything else looks good. I use unilaterism (unilaserism?) engraving and the problem only occurs on the right side (every time a object starts) which sounds like the laser does not have enough power when it hits the surface.
Is there a setting or an idea how to improve this?
thanks,
tm
thanks,
tm
