Machine is cutting a reversed image (mirrored left to right)
Maker23
Post by Maker23 »
We bought our machine assembled from you (came to Sacramento to pick it up a few weeks ago). It's running great except it's cutting mirror images. Not sure if it was always doing this because our early tests were all simple rectangles :)
I see this has happened to people before on the forums but I don't see what the fix is?
-shoshana
Re: Machine is cutting a reversed image (mirrored left to ri
Hello Shoshana:
Check the setup of "Position relative". Make sure that the Home setup (Left Top) matched the setup on the setup on the Position relative. If you chosen it wrong, mirror image may happened. See manual also
(in China)
