Hello!
I'm having a weird problem! I can not save my user parameters.
I have a new stronger steppermotor and so i want to increase the engraving_acc. but for some reason when I insert a new value it saves (no error, just like normal) but when I check "Read" to see the info in the DSP it changes back to the previous value.
I can change and save Manufacturer value's so thats a bit weard.
Who can give me some advice?
can't save user parameters
Jacala
Jacala
Re: can't save user parameters
here some specs:
Lasercad 6.27
main board: 7.12.09.21
LCD board: 5.12.02.29
And I found the problem. Manufacture parameters was set to a low value....... So that overrides the use specs.
Sorry, hopefully someone can use this info!
Lasercad 6.27
Users browsing this forum: Bing [Bot] and 49 guests
