What additional items do I need to successfully run this machine?
1. A printer cable (DB25 or Centronics connector?)
2. A computer running Mach3
3. A 220 volt AC power source (or does it come with a 110v. to 220v. transformer?)
4. A water chiller with a pump (what temperature?)
5. An air pump/compressor (What pressure and volume?)
6. An exhaust fan with ducting to the outside (What diameter connection and required CFM?)
Thanks in advance for your reply.
Additional items needed to run 40 watt Mach3 laser engraver
Re: Additional items needed to run 40 watt Mach3 laser engraver
1. DB25 cable (included)
2. March3 Release R3 and above
3. 110V > 220V Stepping up Transformer (800Watt ~ 1000Watt), not included
4. Pump include. A one gallon water container should be good enough. 30'C
5. Not support. We may customize one for a fee
6. Air blower included
randysworkshop wrote:What additional items do I need to successfully run this machine?
Users browsing this forum: No registered users and 72 guests
