Is there is any way of getting the files off the laser cutter back on to a computer?
Suffered a hard drive failure and got some files on a USB but how can move files from the K40 to the computer please?
Thank you
Bazza
Move files from laser to computer?
Re: Move files from laser to computer?
Insert a disk in the controller and hit file->enter->select file->enter->copy to UDisk-> enter. You'll have to do it for each file.
Yes but laser cad or turbo cad won't recognize it?bsm2003 wrote:Insert a disk in the controller and hit file->enter->select file->enter->copy to UDisk-> enter. You'll have to do it for each file.
It doesn't recognize Ud5 files even on the computer to open or edit. You should always save them in the editable format before saving them to the upload format. If you didn't and your hd died not much you can do but start over.
