DSP panel 'square' cut possible issue?
Posted: Wed Jun 17, 2015 9:19 am
Hi all,
I think I've got my first k40 setup now - I've done my mirror alignments and such and have my focal point figured out ( I think ) using the AA head and a 63.5mm focal lens ( yeah, I need to get a shorter one for most of my work ). I also have the LO Z table installed.
The question I have for all you who are much more experienced than I is this: when I choose to draw a square from the DSP panel menu, I'm noticing the area of the square cut near the origin ( the upper left ) is a much finer and weaker cut then, say, the upper right or lower right - it isn't cutting the same throughout the square. I'm assuming that isn't normal and an indication that the machine isn't quite setup right yet - would that be due to any mirror alignments or could it possibly be my Z table isn't running level ? I did adjust all four of my brass nuts on the Z table to equalize them during installation, but maybe not good enough.
So, may I ask what you suggest I start checking ?
Thanks very much for reading and any suggestions :>
