Page 3 of 4
Re: Larger tube for D40 or K40 (1000mm tube upgrade)
Posted: Wed Aug 12, 2015 10:30 pm
by Tim
Are these cabinet extensions going to be made again any time soon? Lowering the mounts seems like a simple milling job. One could also create all new mounts if desired. You could even add some shim stock to the mirror mounts to make up the difference.
-Tim
Posted: Thu Aug 13, 2015 3:32 pm
Have ordered 50units.
My staff in China will send me 5~10 units at a time till an ocean shipment booked and I can import in a lot
It may take 3 weeks to receive the small order so be patience.
Posted: Wed Aug 19, 2015 10:06 pm
by Tim
I'm committed now, I cut a 4-1/2" hole in the body. I used a hole saw from Lowes and a .5 amp, 1/2" drill. It worked out very well.
-Tim
Posted: Fri Sep 04, 2015 7:14 pm
by hayesjl77
Tim wrote:I'm committed now, I cut a 4-1/2" hole in the body. I used a hole saw from Lowes and a .5 amp, 1/2" drill. It worked out very well.
-Tim
I did the 1000mm tube upgrade today just waiting for a case extension. sticks out about 15 inches when mounted right.
Posted: Sat Sep 05, 2015 6:20 am
by Tim
Do you have any photos?
-Tim
Posted: Sat Sep 05, 2015 5:32 pm
by hayesjl77
- 20150905_202738.jpg (75.5 KiB) Viewed 25361 times
- 20150905_202732.jpg (65.09 KiB) Viewed 25361 times
Posted: Sun Sep 06, 2015 3:06 am
by Techgraphix
tricky!
Find a decent cover fast...
Posted: Sun Sep 06, 2015 11:10 am
by hayesjl77
Techgraphix wrote:tricky!
Still waiting on LO guys to get the covers in lol.
Posted: Mon Sep 14, 2015 5:31 pm
by Tim
My cover came in and I have a few comments. The hole pattern is accurate but they don't match the drawing. I'm glad I waited for the cover before drilling the mounting holes. Once mounted, the assembly is very sturdy. There is no need for additional gussets. I've painted mine to match the machine. Rust-Oleum "Sail Blue #7724" is a pretty close match. Buying the cover is a no brainer if you are going with the 1000m tube.
-Tim
Posted: Fri Sep 18, 2015 3:22 pm
by hayesjl77
This is what it looks like. Mounting was perfect with a 4 inch hole centered on the back chamber.
Posted: Sun Oct 04, 2015 2:27 am
by RomeoKilo
I'm in the market for a new tube and thinking i might as well go this route.
Question- Was it worth the upgrade to a larger tube?
In the real world have you noticed enough of power gain to justify the cost?
I'm ready to click on buy, just after some persuasion.
Posted: Wed Oct 14, 2015 3:50 pm
by PeterE
Any news on this?
Peter.
Posted: Tue Mar 08, 2016 10:56 am
by Q*bert
hayesjl77 wrote:This is what it looks like. Mounting was perfect with a 4 inch hole centered on the back chamber.
So how do you like your 45W tube? Is it noticeably better than the stock K40 tube?
Posted: Mon May 15, 2017 10:45 am
by OzAdr1an
I got one of these tubes Mid-2016, which means its the 55mm one not the current 50mm one. Did anyone who had this one end up just shaving down the current mounts, or was there a better approach found ?
Cheers
Adrian
Posted: Sat May 20, 2017 6:34 am
by Tim
I was able to use the stock mounts and simply adjust the mirrors. Your mileage may vary.
-Tim
