Ammeter wiring
bing1982
Ammeter wiring
Post by bing1982 »
I've seen the PDF file for the wiring of the Ammeter, which is fine, but a little confused as to the wiring of the power converter.
Looking at some date sheets, and the block, I think I've found that pin 1 is ground, and pin 2 is 24V. I'm not sure which pins go to the ammeter display though. Any help would be great as this is the last thing I need to wire in for the conversion.
NickWL
Re: Ammeter wiring
Post by NickWL »
Go here, pick the relevant model and click for wiring/pinout:
http://www.lightobject.com/Search.aspx?k=converter
