Urgent help needed JLD7100
Hello. I need some help, please, setting up this controller. i have a type "J" thermocouple and am using the relay output. I want a simple on off control to drive a .5A pump. On at 130 degress F and off at 140 degrees F. I cannot seep to find out how to get the controller to do this. Any help is greatly appreciated. Thanks.
Re: Urgent help needed JLD7100
1) Prgram the controller for "J" thermocouple
2) Set output mode "Inty" to 1
3) Connect your fan the the relay "J1" in series so that hte relay can control it On or Off
If you can't get the P,I,D working properly, may be you should use the "Auto" to tune the the PID parameters but it may take as short as mintues to as long as hours to complete the tuning.
Please read through the manual and see the example below of that
