PID help needed !
PID help needed !
Not sure if I am on the right track programing the TCG-6131P so I thought best if I just upload it here and show you the default and my current setting, and hopefully I get some input on it.... Something is not right cause as soon as I connect the heating wire to the heater relay starts working for a very short time and then the relay stays on longer than supposed to so I have to turn the thing. The value on the Pv side keeps going down to Zero then back up again while still heating. I heard a lot of good thing about this PID... I know it gotta be me!
- CTG-6131P spec.pdf
- (66.04 KiB) Downloaded 201 times
- PID on at 33°c (2).pdf
- (919.64 KiB) Downloaded 197 times
- PID 2 of at 33°c.pdf
- (1.95 MiB) Downloaded 166 times
