NEMA 23 3 PHASE 573S15 5.2A 212IN-OZ STEPPER MOTOR
Posted: Thu Nov 01, 2018 9:18 am
Okay - maybe I was a bit ambitious for a first build but I'm sure I can do it.... I think.
It would certainly help if there wasn't so much conflicting information though!
Here's my latest dilemma. MY Y motor only has 3 wires as stated below but when pulling up the product page it lists it as having 6 wires....
Additionally, as you can see below, the X motor claims to have 3 wires but mine has 6...? This matches the product page.
So, setting the driver to 5.8 A for a test, I get a very shaky start until the DSP boots. According to the diagram I was sent, there is a jump between PUL+ and DIR+ ... anyone know if this is correct?
Specification:
X motor:
Brand: Lightobject 573S09 3-phase
Step angle: 1.2 degree
Torque: 128 oz-in
Current: 3.5 A
Resistance: 1.3 ohm
Inductance: 1.7 mH
Detent torque: 4 N.cm
No. Wire: 3
Weight: 0.75Kg (1.65 lb)
Y motor:
Brand: Lightobject 573S15 3-phase
Torque: 188oz-in
Current: 5.8A
Resistance: 0.7ohm
Inductance: 1.35mH
Detente torque: 6.8 N.cm
No. Wire: 3
Weight: 1.1Kg (2.4lb)
Specification:
X motor:
Torque: 128 oz-in
Current: 3.5 A
Resistance: 1.3 ohm
Inductance: 1.7 mH
No. Wire: 3
Y motor:
Torque: 188oz-in
Current: 5.8A
Resistance: 0.7ohm
Inductance: 1.35mH
No. Wire: 3
