Question about power switches
Posted: Wed Feb 19, 2014 3:48 am
by Meshal
I'm going to put a power switch on each power supply on my DIY laser machine, but before to do that I need to know the maximum INPUT current (AC) for these PS's so that I can select a proper current rating for these switches, the following power supplies are :
1- 80W PWM CO2 Laser Power Supply (220V) ------- (SN/ LSR-JN80WCO2-2)
2- Dual DC 36V & 24V 10A Switching Power Supply ------- (SN/ EPS-D3624V10A)
3- DC 24V 5A Switching Power Supply ------- (SN/ EPS-D24V5APS)
Re: Question about power switches
Posted: Fri Feb 21, 2014 10:07 am
Laser only have 10% efficiency. So, 80W peak power means that it take 800W
Considering fully loaded:
1) 800W
2) 360W+120W
3) 120W
Total: 1400W x 20% extra = 1680W
If it is driven by AC110V, the current is 15.3A (16A)
You may want to use a Relay to seves as "switch" as it is hardly you can find a single switch capable to handle over 15A. And, it is not "safe" to swith On/Off of such high current loading by hand. Attach a small switch (any switch that capable to handle 1A current: easy to find) to turn the Relay On and Off, which in turn to turn the machine On or Off. Follow me?
You may also consider a Sold Relay (SSR) 25A for less than $10 on my site (need to get heatsink as well). It needs DC source 3~36V to turn it On which is easy to get it from current the system.
Posted: Sat Feb 22, 2014 7:24 am
by Meshal
So helpful , thanks Marco for the clarification and infinite support !.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
