-power supply spec:
* Power: 120W~150Watt (180W peak)
* Triggering Voltage: 40KV
* Operating Voltage: 22KV
* Current: 38mA
Will this damage the 80w tube ? Thanks
Can 100-150w powersupply use for 8ow tube
ltran2000
twehr
Re: Can 100-150w powersupply use for 8ow tube
You will have to measure the current and ensure you never exceed the recommended max current for your 80watt tube. Exceeding the recommended current will provide poor results AND shorten the tube's life. If you are using a DSP, you may want to set the max power percent to something that will ensure the current is not exceeded.ltran2000 wrote:-power supply spec:
* Current: 38mA
ltran2000
Thanks, Tim
Thank you for your answer.
