12 Channel Wireless receiver-new chip,no buzzer-program code
jmcclay
Post by jmcclay »
Here are the codes for programming the new style 12 Channel wireless receivers. For newly encoded remote or mode change.
1. Press and hold program button for 10 sec.(one bright led blink and then 1 dim led blink) release
2. Press and hold program button until one bright LED blink. release.
3. Press the corresponding program code. (Note: the codes are different than the old style- see below)
Button Function
1 Latch
2 Momentary
4 Toggle
8 1 thru 6 Momentary, 7 thru 12 Toggle
The encoding/decoding address is configured on the remotes by jumpering or removing connection on the chip described in the instructions. After doing this the receiver needs to be programmed to accept the remote.
Note: These units blink the LED every time the receive a RF signal from any remote, they only operate relays for remotes that have the same encoding as programmed. Multiple remotes can have the same encoded address.
terrylndrs
Re: 12 Channel Wireless receiver-new chip,no buzzer-program code
Post by terrylndrs »
How do you program the old style?
support.lightobject.com
