Latest Update Oct 24, 2020
If you downloaded a patch "V15.01.20-LIB.upd" that I posted a week ago, you need to download the following new patch to replace it because there was a bug found from the previous version. It was still pointing a rotary to the Y axis but we need it to point the rotary to the 4th-axis (U axis). Please report to me if there is another issue! We're alliance of Ruida, Trocen, PH, and TopWisdom
With this new patch, the U axis is dedicated to a rotary attachment. Unlike the R6442G controller where you need to disconnect the Y-axis and hook it u to a rotary, load parameters for the rotary in order to enable the rotary.
Fix: Rotary was pointed to the Y-axis. Fixed: Rotary pointed to the U axis. Do not apply it to other controller. It is designed for the R6445G only!
download/DSP/Ruida/RDC6445G-V15.01.22-LIB.upd
Disclaimer
Use it at your own risk. We will not be liable or responsible for any failure or damage caused by the patch
*Update: Rotary support Patch for Ruida R6445G DSP laser controller *
Users browsing this forum: No registered users and 18 guests
